Ana içeriğe geç
Sol Republic Deck Play/Pause Button Replacement
Neye ihtiyacın var
  1. Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: adım 1, 3 resimden 1. Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: adım 1, 3 resimden 2. Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: adım 1, 3 resimden 3.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry the front face plate from the bottom half of the speaker by inserting the spudger edge into the the middle groove.
    • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
    FixBot'a Sor
    Yorum Ekle
  2. Sol Republic Deck Play/Pause Button Replacement: adım 2, 1 resimden 1.
    • On the front face of the device, locate the green plastic Motorola (M) button that controls the playing and pausing of music.
    FixBot'a Sor
    Yorum Ekle
  3. Sol Republic Deck Play/Pause Button Replacement: adım 3, 1 resimden 1.
    • Using your finger, push the M button towards the inside of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Sol Republic Deck Play/Pause Button Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the tweezers, grab the button as it comes through and pull it carefully off of the pegs.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 1,149
