Ana içeriğe geç
Sol Republic Deck Speaker Replacement
Neye ihtiyacın var
  1. Sol Republic Deck Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Speaker Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Speaker Replacement: adım 3, 1 resimden 1.
    • Unplug the ribbon cable from the port.
  4. Sol Republic Deck Speaker Replacement: adım 4, 1 resimden 1.
    • Unscrew 5 3.63 mm Phillips #0 screws securing the circuit board.
  5. Sol Republic Deck Speaker Replacement: adım 5, 1 resimden 1.
    • Unscrew 15 6.15 mm Phillips #0 screws and lift the black plastic plate from the case.
  6. Sol Republic Deck Speaker Replacement: adım 6, 1 resimden 1.
    • Remove 4 3.63 mm Phillips #0 screws holding the bracket.
  7. Sol Republic Deck Speaker Replacement: adım 7, 1 resimden 1.
    • Use the hairdryer to soften the glue holding the speaker to the plastic plate.
  8. Sol Republic Deck Speaker Replacement: adım 8, 1 resimden 1.
    • Gently pull up on the speaker.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jonathan Holtman
368 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Baechle Spring 2017 IUPUI, Team S3-G1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 2,142
