Ana içeriğe geç
Sol Republic Deck Volume Buttons Replacement
Neye ihtiyacın var
  1. Sol Republic Deck Volume Buttons Replacement, Volume Buttons: adım 1, 2 resimden 1. Sol Republic Deck Volume Buttons Replacement, Volume Buttons: adım 1, 2 resimden 2.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • To separate the front face plate from the bottom half of the speaker, insert a spudger into the the middle groove.
    • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
    FixBot'a Sor
    Yorum Ekle
  2. Sol Republic Deck Volume Buttons Replacement: adım 2, 2 resimden 1. Sol Republic Deck Volume Buttons Replacement: adım 2, 2 resimden 2.
    • Locate the black plastic volume buttons on each side of the back of the speaker face.
    • A piece of black tape on the side panel may also be covering the yellow connector tip that holds the volume button in place. Remove the black tape if necessary.
    FixBot'a Sor
    Yorum Ekle
  3. Sol Republic Deck Volume Buttons Replacement: adım 3, 1 resimden 1.
    • Using the plastic spudger, pry the button from the front plate of the speaker. The volume button is connected to the speaker by a plastic tab that has blue glue holding it down. The entire volume button can be removed from the front plate by carefully using the spudger to lift it up until it comes off.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Thanks for the help
Rebecca Parrish - Yanıt Paylaş
No problem! Glad you were able to fix your speaker :)
Shelby Ray - Yanıt Paylaş
So I dropped my speaker from 2 ft and the volume up doesn't work even after opening it up and trying to replace it. Is there any thing I may have missed?
nick ed - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 1,620
