Ana içeriğe geç
Solio Bolt Battery Replacement
Neye ihtiyacın var
  1. Solio Bolt Battery Replacement, Remove Screw: adım 1, 1 resimden 1.
    • Open the solar panel of the Solio Bolt. Using a philips screwdriver, remove the screw.
  2. Solio Bolt Battery Replacement, Open Case: adım 2, 1 resimden 1.
    • Use a plastic spudger to pry apart the case.
  3. Solio Bolt Battery Replacement, Remove The 'Battery Holder' Assembly: adım 3, 2 resimden 1. Solio Bolt Battery Replacement, Remove The 'Battery Holder' Assembly: adım 3, 2 resimden 2.
    • Use a philips screwdriver to remove the three screws securing the battery cradle to the device case.
  4. Solio Bolt Battery Replacement, Free Motherboard: adım 4, 2 resimden 1. Solio Bolt Battery Replacement, Free Motherboard: adım 4, 2 resimden 2.
    • Move the battery slightly, the motherboard can now be lifted from the device case.
  5. Solio Bolt Battery Replacement, Discconnect Battery: adım 5, 1 resimden 1.
    • On the underside of the motherboard, remove the battery lead from its connecting terminal.
Sonuç
Ethel
324 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Shastany Fall 2014 UMass Dartmouth, Team 1-3, Shastany Fall 2014 üyesi
UMASSD-SHASTANY-F14S1G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 391
