Giriş
Removing the circuit board will allow you to more easily solder on the circuit board.
  1. Turn off the device by pressing on the clear power button behind the device.
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Using the plastic opening tools, gently pry open the side of the large panel. Keeping the tool in, slowly slide the tool along the side of the panel. Keeping the tool in, slowly slide the tool along the side of the panel.
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Rotate the device 180 degrees. Make sure the opening on other side of the device does not snap closed.
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  6. Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel. Using both hands, slowly pull apart the back panel from the rest of the device.
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  7. Softly pinch the red and blue wires  close to the white connector. To pull the wires out, wiggle them back and forth until the connector is fully out.
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  8. Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  9. Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
Sonuç
Eric Padilla
201 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 4-28, Amido Fall 2013 Cal Poly, Team 4-28, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G28
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 120
