Ana içeriğe geç
Sonos Connect Top Motherboard Replacement
Neye ihtiyacın var
  1. Sonos Connect Top Motherboard Replacement, WIFI Card: adım 1, 3 resimden 1. Sonos Connect Top Motherboard Replacement, WIFI Card: adım 1, 3 resimden 2. Sonos Connect Top Motherboard Replacement, WIFI Card: adım 1, 3 resimden 3.
    • Start by using a spudger or plastic opening tool to remove the bottom cover.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Once enough of the glue is removed, peel the cover off by hand,
  2. Sonos Connect Top Motherboard Replacement: adım 2, 3 resimden 1. Sonos Connect Top Motherboard Replacement: adım 2, 3 resimden 2. Sonos Connect Top Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the four 7.5mm length Philips head screws under the rubber cover.
  3. Sonos Connect Top Motherboard Replacement: adım 3, 3 resimden 1. Sonos Connect Top Motherboard Replacement: adım 3, 3 resimden 2. Sonos Connect Top Motherboard Replacement: adım 3, 3 resimden 3.
    • Use a nylon spudger to unsnap the bottom from the sides.
    • Pry until the remaining three points are unsnapped.
    • Once unsnapped, lift the cover.
  4. Sonos Connect Top Motherboard Replacement: adım 4, 2 resimden 1. Sonos Connect Top Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the connection for the front buttons to fully remove the cover.
  5. Sonos Connect Top Motherboard Replacement: adım 5, 2 resimden 1. Sonos Connect Top Motherboard Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
    • Gently pull the wires at the connection point to disconnect them from the motherboard.
  6. Sonos Connect Top Motherboard Replacement: adım 6, 2 resimden 1. Sonos Connect Top Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the two pieces of glue holding the WIFI card in place.
  7. Sonos Connect Top Motherboard Replacement: adım 7, 3 resimden 1. Sonos Connect Top Motherboard Replacement: adım 7, 3 resimden 2. Sonos Connect Top Motherboard Replacement: adım 7, 3 resimden 3.
    • Scrape the glued pad underneath the WIFI card to seperate the card from the board.
    • Push apart the two clips holding the WIFI card in the connection.
    • Pull the WIFI card out of the connection.
    • When putting the new WIFI card in, put the card in the connector first, then push downward until it clicks.
  8. Sonos Connect Top Motherboard Replacement, Top Motherboard: adım 8, 1 resimden 1.
    • Remove the 7mm length Phillips screw holding the board in place.
  9. Sonos Connect Top Motherboard Replacement: adım 9, 2 resimden 1. Sonos Connect Top Motherboard Replacement: adım 9, 2 resimden 2.
    • Flip the board over to access the Molex Cable.
  10. Sonos Connect Top Motherboard Replacement: adım 10, 1 resimden 1.
    • Disconnect the Molex Cable from the top motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Clark Snyder
483 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Baechle Spring 2016 IUPUI, Team 3-2, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S3G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,967
