Ana içeriğe geç
Sonos One Control Panel & Microphone Replacement
Neye ihtiyacın var
    1. Sonos One Control Panel & Microphone Replacement, Protective Cover: adım 1, 3 resimden 1. Sonos One Control Panel & Microphone Replacement, Protective Cover: adım 1, 3 resimden 2. Sonos One Control Panel & Microphone Replacement, Protective Cover: adım 1, 3 resimden 3.
      • Disconnect all power cords.
      • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
      • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
      FixBot'a Sor
      Yorum Ekle
    2. Sonos One Control Panel & Microphone Replacement: adım 2, 3 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 2, 3 resimden 2. Sonos One Control Panel & Microphone Replacement: adım 2, 3 resimden 3.
      • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
      FixBot'a Sor
      Yorum Ekle
    3. Sonos One Control Panel & Microphone Replacement: adım 3, 2 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 3, 2 resimden 2.
      • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
      FixBot'a Sor
      Yorum Ekle
    4. Sonos One Control Panel & Microphone Replacement: adım 4, 3 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 4, 3 resimden 2. Sonos One Control Panel & Microphone Replacement: adım 4, 3 resimden 3.
      • The protective cover clip is very thin and deforms easily.
      • Remove the single 8mm Torx T10 screw and protective cover clip.
      FixBot'a Sor
      Yorum Ekle
    5. Sonos One Control Panel & Microphone Replacement: adım 5, 2 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 5, 2 resimden 2.
      • Slide the protective cover upwards to remove.
      FixBot'a Sor
      Yorum Ekle
    1. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: adım 6, 3 resimden 1. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: adım 6, 3 resimden 2. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: adım 6, 3 resimden 3.
      • Use the pointed end of a spudger to remove the covers that hide the screws.
      • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
      FixBot'a Sor
      Yorum Ekle
    2. Sonos One Control Panel & Microphone Replacement: adım 7, 2 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 7, 2 resimden 2.
      • With the front of the unit facing you, lift the control panel up using your thumbs.
      • There's a ribbon cable attaching the control panel to the speaker so work slowly.
      FixBot'a Sor
      Yorum Ekle
    3. Sonos One Control Panel & Microphone Replacement: adım 8, 3 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 8, 3 resimden 2. Sonos One Control Panel & Microphone Replacement: adım 8, 3 resimden 3.
      • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
      • Pull the control panel ribbon cable out of its socket.
      FixBot'a Sor
      Yorum Ekle
    4. Sonos One Control Panel & Microphone Replacement: adım 9, 2 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 9, 2 resimden 2.
      • Pull the control panel away from the speaker to separate.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Marcus Glowa
1.134 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G1
3 Üyeler
19 adet Kılavuz yazıldı
1Rehber Yorum
where can I buy a replacement control panel?
Chris Myers - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 27
Son 30 gün: 95
Her zaman: 8,551
