Ana içeriğe geç
Sonos One Control Panel & Microphone Replacement
Neye ihtiyacın var
  1. Sonos One Control Panel & Microphone Replacement, Protective Cover: adım 1, 3 resimden 1. Sonos One Control Panel & Microphone Replacement, Protective Cover: adım 1, 3 resimden 2. Sonos One Control Panel & Microphone Replacement, Protective Cover: adım 1, 3 resimden 3.
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Control Panel & Microphone Replacement: adım 2, 3 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 2, 3 resimden 2. Sonos One Control Panel & Microphone Replacement: adım 2, 3 resimden 3.
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Control Panel & Microphone Replacement: adım 3, 2 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 3, 2 resimden 2.
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Control Panel & Microphone Replacement: adım 4, 3 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 4, 3 resimden 2. Sonos One Control Panel & Microphone Replacement: adım 4, 3 resimden 3.
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Control Panel & Microphone Replacement: adım 5, 2 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 5, 2 resimden 2.
    • Slide the protective cover upwards to remove.
  6. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: adım 6, 3 resimden 1. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: adım 6, 3 resimden 2. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: adım 6, 3 resimden 3.
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Control Panel & Microphone Replacement: adım 7, 2 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 7, 2 resimden 2.
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Control Panel & Microphone Replacement: adım 8, 3 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 8, 3 resimden 2. Sonos One Control Panel & Microphone Replacement: adım 8, 3 resimden 3.
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Control Panel & Microphone Replacement: adım 9, 2 resimden 1. Sonos One Control Panel & Microphone Replacement: adım 9, 2 resimden 2.
    • Pull the control panel away from the speaker to separate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marcus Glowa
965 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G1
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
where can I buy a replacement control panel?
Chris Myers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 91
Her zaman: 6,420
