Ana içeriğe geç
Sonos One Power Adapter Replacement
Neye ihtiyacın var
  1. Sonos One Power Adapter Replacement, Protective Cover: adım 1, 3 resimden 1. Sonos One Power Adapter Replacement, Protective Cover: adım 1, 3 resimden 2. Sonos One Power Adapter Replacement, Protective Cover: adım 1, 3 resimden 3.
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Power Adapter Replacement: adım 2, 3 resimden 1. Sonos One Power Adapter Replacement: adım 2, 3 resimden 2. Sonos One Power Adapter Replacement: adım 2, 3 resimden 3.
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Power Adapter Replacement: adım 3, 2 resimden 1. Sonos One Power Adapter Replacement: adım 3, 2 resimden 2.
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Power Adapter Replacement: adım 4, 3 resimden 1. Sonos One Power Adapter Replacement: adım 4, 3 resimden 2. Sonos One Power Adapter Replacement: adım 4, 3 resimden 3.
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Power Adapter Replacement: adım 5, 2 resimden 1. Sonos One Power Adapter Replacement: adım 5, 2 resimden 2.
    • Slide the protective cover upwards to remove.
  6. Sonos One Power Adapter Replacement, Control Panel & Microphone: adım 6, 3 resimden 1. Sonos One Power Adapter Replacement, Control Panel & Microphone: adım 6, 3 resimden 2. Sonos One Power Adapter Replacement, Control Panel & Microphone: adım 6, 3 resimden 3.
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Power Adapter Replacement: adım 7, 2 resimden 1. Sonos One Power Adapter Replacement: adım 7, 2 resimden 2.
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Power Adapter Replacement: adım 8, 3 resimden 1. Sonos One Power Adapter Replacement: adım 8, 3 resimden 2. Sonos One Power Adapter Replacement: adım 8, 3 resimden 3.
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Power Adapter Replacement: adım 9, 2 resimden 1. Sonos One Power Adapter Replacement: adım 9, 2 resimden 2.
    • Pull the control panel away from the speaker to separate.
  10. Sonos One Power Adapter Replacement, Power Adapter Receptacle: adım 10, 3 resimden 1. Sonos One Power Adapter Replacement, Power Adapter Receptacle: adım 10, 3 resimden 2. Sonos One Power Adapter Replacement, Power Adapter Receptacle: adım 10, 3 resimden 3.
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
  11. Sonos One Power Adapter Replacement: adım 11, 2 resimden 1. Sonos One Power Adapter Replacement: adım 11, 2 resimden 2.
    • Using a plastic opening tool, separate the motherboard from the speaker.
  12. Sonos One Power Adapter Replacement: adım 12, 3 resimden 1. Sonos One Power Adapter Replacement: adım 12, 3 resimden 2. Sonos One Power Adapter Replacement: adım 12, 3 resimden 3.
    • Using your thumb, disconnect the speaker cable from the motherboard.
  13. Sonos One Power Adapter Replacement: adım 13, 3 resimden 1. Sonos One Power Adapter Replacement: adım 13, 3 resimden 2. Sonos One Power Adapter Replacement: adım 13, 3 resimden 3.
    • Disconnect the power adapter plug from the motherboard using your thumb.
  14. Sonos One Power Adapter Replacement: adım 14, 3 resimden 1. Sonos One Power Adapter Replacement: adım 14, 3 resimden 2. Sonos One Power Adapter Replacement: adım 14, 3 resimden 3.
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
  15. Sonos One Power Adapter Replacement: adım 15, 2 resimden 1. Sonos One Power Adapter Replacement: adım 15, 2 resimden 2.
    • Remove the motherboard panel from the speaker housing.
  16. Sonos One Power Adapter Replacement: adım 16, 3 resimden 1. Sonos One Power Adapter Replacement: adım 16, 3 resimden 2. Sonos One Power Adapter Replacement: adım 16, 3 resimden 3.
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Marcus Glowa
965 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 18
Son 30 gün: 92
Her zaman: 7,440
