Ana içeriğe geç
Sonos One Protective Cover Replacement
Neye ihtiyacın var
  1. Sonos One Protective Cover Replacement, Protective Cover: adım 1, 3 resimden 1. Sonos One Protective Cover Replacement, Protective Cover: adım 1, 3 resimden 2. Sonos One Protective Cover Replacement, Protective Cover: adım 1, 3 resimden 3.
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Protective Cover Replacement: adım 2, 3 resimden 1. Sonos One Protective Cover Replacement: adım 2, 3 resimden 2. Sonos One Protective Cover Replacement: adım 2, 3 resimden 3.
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Protective Cover Replacement: adım 3, 2 resimden 1. Sonos One Protective Cover Replacement: adım 3, 2 resimden 2.
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Protective Cover Replacement: adım 4, 3 resimden 1. Sonos One Protective Cover Replacement: adım 4, 3 resimden 2. Sonos One Protective Cover Replacement: adım 4, 3 resimden 3.
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Protective Cover Replacement: adım 5, 2 resimden 1. Sonos One Protective Cover Replacement: adım 5, 2 resimden 2.
    • Slide the protective cover upwards to remove.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Marcus Glowa
1.046 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G1
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Well done! I would add a little bit about how much adhesive there is underneath the rubber feet as well as the screw cover.
Joshua Pinter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 5,362
