Ana içeriğe geç
Sonos One Tweeter Diaphragm Repair/ Replacement
Neye ihtiyacın var
  1. Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: adım 1, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: adım 1, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: adım 1, 3 resimden 3.
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
    FixBot'a Sor
    Yorum Ekle
  2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 2, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 2, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 2, 3 resimden 3.
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 3, 2 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 3, 2 resimden 2.
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
    FixBot'a Sor
    Yorum Ekle
  4. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 4, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 4, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 4, 3 resimden 3.
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
    FixBot'a Sor
    Yorum Ekle
  5. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 5, 2 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 5, 2 resimden 2.
    • Slide the protective cover upwards to remove.
    FixBot'a Sor
    Yorum Ekle
  6. Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: adım 6, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: adım 6, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: adım 6, 3 resimden 3.
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
    FixBot'a Sor
    Yorum Ekle
  7. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 7, 2 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 7, 2 resimden 2.
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
    FixBot'a Sor
    Yorum Ekle
  8. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 8, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 8, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 8, 3 resimden 3.
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
    FixBot'a Sor
    Yorum Ekle
  9. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 9, 2 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 9, 2 resimden 2.
    • Pull the control panel away from the speaker to separate.
    FixBot'a Sor
    Yorum Ekle
  10. Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: adım 10, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: adım 10, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: adım 10, 3 resimden 3.
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
    FixBot'a Sor
    Yorum Ekle
  11. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 11, 2 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 11, 2 resimden 2.
    • Using a plastic opening tool, separate the motherboard from the speaker.
    FixBot'a Sor
    Yorum Ekle
  12. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 12, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 12, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 12, 3 resimden 3.
    • Using your thumb, disconnect the speaker cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 13, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 13, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 13, 3 resimden 3.
    • Disconnect the power adapter plug from the motherboard using your thumb.
    FixBot'a Sor
    Yorum Ekle
  14. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 14, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 14, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 14, 3 resimden 3.
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
    FixBot'a Sor
    Yorum Ekle
  15. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 15, 2 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 15, 2 resimden 2.
    • Remove the motherboard panel from the speaker housing.
    FixBot'a Sor
    Yorum Ekle
  16. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 16, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 16, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 16, 3 resimden 3.
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
    FixBot'a Sor
    Yorum Ekle
  17. Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: adım 17, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: adım 17, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: adım 17, 3 resimden 3.
    • Disconnect the woofer cables.
    • If removing the tabs is difficult, the flat end of the spudger may be used to depress the middle tab and then the tab may be pulled to disconnect.
    FixBot'a Sor
    Yorum Ekle
  18. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 18, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 18, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 18, 3 resimden 3.
    • Disconnect the cables from the tweeter.
    FixBot'a Sor
    Yorum Ekle
  19. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 19, 3 resimden 1. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 19, 3 resimden 2. Sonos One Tweeter Diaphragm Repair/ Replacement: adım 19, 3 resimden 3.
    • Remove the four 10mm Torx T10 screws from the tweeter.
    • Remove the tweeter from the speaker housing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marcus Glowa
1.134 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G1
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 57
Her zaman: 3,903
