Ana içeriğe geç
Sonos Play 3 Motherboard Replacement
Neye ihtiyacın var
  1. Sonos Play 3 Motherboard Replacement, Speaker Grille: adım 1, 2 resimden 1. Sonos Play 3 Motherboard Replacement, Speaker Grille: adım 1, 2 resimden 2.
    • Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
  2. Sonos Play 3 Motherboard Replacement: adım 2, 1 resimden 1.
    • Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • There may be a kind of black sticky adhesive holding the screen clips to the rest of the body; however, it was previously removed on our model.
  3. Sonos Play 3 Motherboard Replacement, Front Speaker Panel: adım 3, 2 resimden 1. Sonos Play 3 Motherboard Replacement, Front Speaker Panel: adım 3, 2 resimden 2.
    • Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
    • Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
    • Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
  4. Sonos Play 3 Motherboard Replacement: adım 4, 3 resimden 1. Sonos Play 3 Motherboard Replacement: adım 4, 3 resimden 2. Sonos Play 3 Motherboard Replacement: adım 4, 3 resimden 3.
    • Remove the front panel carefully.
    • Note that there are two layers to the panel that should stay in their original order.
  5. Sonos Play 3 Motherboard Replacement: adım 5, 2 resimden 1. Sonos Play 3 Motherboard Replacement: adım 5, 2 resimden 2.
    • Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  6. Sonos Play 3 Motherboard Replacement: adım 6, 2 resimden 1. Sonos Play 3 Motherboard Replacement: adım 6, 2 resimden 2.
    • Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
  7. Sonos Play 3 Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Sonos Play 3 Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Disconnect the motherboard from the power supply board by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  8. Sonos Play 3 Motherboard Replacement: adım 8, 2 resimden 1. Sonos Play 3 Motherboard Replacement: adım 8, 2 resimden 2.
    • Disconnect the motherboard from the volume button board by gently grabbing the connector and pulling it towards you.
  9. Sonos Play 3 Motherboard Replacement: adım 9, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the 4 screws securing the two plastic panels down.
  10. Sonos Play 3 Motherboard Replacement: adım 10, 2 resimden 1. Sonos Play 3 Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the two plastic panels on either side of the device that hold the motherboard and power supply board in place.
  11. Sonos Play 3 Motherboard Replacement: adım 11, 1 resimden 1.
    • Using a Phillips screwdriver, unscrew the two screws in the back of the device that hold the motherboard in place.
  12. Sonos Play 3 Motherboard Replacement: adım 12, 3 resimden 1. Sonos Play 3 Motherboard Replacement: adım 12, 3 resimden 2. Sonos Play 3 Motherboard Replacement: adım 12, 3 resimden 3.
    • Gently remove the motherboard from the Sonos device by sliding it straight back towards you.
    • When putting the motherboard back inside the device, make sure it slides in the slots smoothly on both sides.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Christina Santini
1.350 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-6, Maness Spring 2016 Cal Poly, Team 25-6, Maness Spring 2016 üyesi
CPSU-MANESS-S16S25G6
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Where can I buy a new power board?
Roger Beasley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 16
Son 30 gün: 46
Her zaman: 4,560
