Ana içeriğe geç
Sonos Playbase A Speaker from the Main Array Replacement
Neye ihtiyacın var
  1. Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: adım 1, 3 resimden 1. Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: adım 1, 3 resimden 2. Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Pro Tech Toolkit
    $74.95
    Satın Al
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase A Speaker from the Main Array Replacement: adım 2, 2 resimden 1. Sonos Playbase A Speaker from the Main Array Replacement: adım 2, 2 resimden 2.
    Pro Tech Toolkit
    $74.95
    Satın Al
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase A Speaker from the Main Array Replacement: adım 3, 2 resimden 1. Sonos Playbase A Speaker from the Main Array Replacement: adım 3, 2 resimden 2.
    Pro Tech Toolkit
    $74.95
    Satın Al
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase A Speaker from the Main Array Replacement, Main Speaker Array: adım 4, 2 resimden 1. Sonos Playbase A Speaker from the Main Array Replacement, Main Speaker Array: adım 4, 2 resimden 2.
  5. Sonos Playbase A Speaker from the Main Array Replacement: adım 5, 2 resimden 1. Sonos Playbase A Speaker from the Main Array Replacement: adım 5, 2 resimden 2.
    • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
    • See Recognizing & Disconnecting Cable Connectors for more information.
  6. Sonos Playbase A Speaker from the Main Array Replacement: adım 6, 3 resimden 1. Sonos Playbase A Speaker from the Main Array Replacement: adım 6, 3 resimden 2. Sonos Playbase A Speaker from the Main Array Replacement: adım 6, 3 resimden 3.
    Pro Tech Toolkit
    $74.95
    Satın Al
    • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
  7. Sonos Playbase A Speaker from the Main Array Replacement: adım 7, 1 resimden 1.
    • Remove the main speaker array by gripping it on both sides and pulling it out.
    • The array may require a significant amount of force to remove.
    • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
    • Do not to yank the array out too suddenly or too far as this may damage the device.
  8. Sonos Playbase A Speaker from the Main Array Replacement: adım 8, 1 resimden 1.
    • Prop the removed main speaker array up on top of the main circuit board.
  9. Sonos Playbase A Speaker from the Main Array Replacement, Speaker from the Main Array: adım 9, 2 resimden 1. Sonos Playbase A Speaker from the Main Array Replacement, Speaker from the Main Array: adım 9, 2 resimden 2.
    Pro Tech Toolkit
    $74.95
    Satın Al
    • Remove the four 11mm T-10 screws from the individual speaker that needs replacement, by turning the screws counterclockwise.
  10. Sonos Playbase A Speaker from the Main Array Replacement: adım 10, 1 resimden 1.
    • Remove the damaged speaker from the array socket, by grasping the speaker with one hand, the array with your other and pulling outward.
  11. Sonos Playbase A Speaker from the Main Array Replacement: adım 11, 2 resimden 1. Sonos Playbase A Speaker from the Main Array Replacement: adım 11, 2 resimden 2.
Sonuç
George Slivka
339 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G2, White Fall 2018 Cal Poly, Team S17-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 2,419
