Ana içeriğe geç
Sonos Playbase IR Reciver Replacement
Neye ihtiyacın var
  1. Sonos Playbase IR Reciver Replacement, Bottom Panel: adım 1, 3 resimden 1. Sonos Playbase IR Reciver Replacement, Bottom Panel: adım 1, 3 resimden 2. Sonos Playbase IR Reciver Replacement, Bottom Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Pro Tech Toolkit
    $79.95
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  2. Sonos Playbase IR Reciver Replacement: adım 2, 2 resimden 1. Sonos Playbase IR Reciver Replacement: adım 2, 2 resimden 2.
    Pro Tech Toolkit
    $79.95
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
    FixBot'a Sor
    Yorum Ekle
  3. Sonos Playbase IR Reciver Replacement: adım 3, 2 resimden 1. Sonos Playbase IR Reciver Replacement: adım 3, 2 resimden 2.
    Pro Tech Toolkit
    $79.95
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
    FixBot'a Sor
    Yorum Ekle
  4. Sonos Playbase IR Reciver Replacement, Main Speaker Array: adım 4, 2 resimden 1. Sonos Playbase IR Reciver Replacement, Main Speaker Array: adım 4, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  5. Sonos Playbase IR Reciver Replacement: adım 5, 2 resimden 1. Sonos Playbase IR Reciver Replacement: adım 5, 2 resimden 2.
    • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
    • See Recognizing & Disconnecting Cable Connectors for more information.
    FixBot'a Sor
    Yorum Ekle
  6. Sonos Playbase IR Reciver Replacement: adım 6, 3 resimden 1. Sonos Playbase IR Reciver Replacement: adım 6, 3 resimden 2. Sonos Playbase IR Reciver Replacement: adım 6, 3 resimden 3.
    Pro Tech Toolkit
    $79.95
    • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
    FixBot'a Sor
    Yorum Ekle
  7. Sonos Playbase IR Reciver Replacement: adım 7, 1 resimden 1.
    • Remove the main speaker array by gripping it on both sides and pulling it out.
    • The array may require a significant amount of force to remove.
    • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
    • Do not to yank the array out too suddenly or too far as this may damage the device.
    FixBot'a Sor
    Yorum Ekle
  8. Sonos Playbase IR Reciver Replacement: adım 8, 1 resimden 1.
    • Prop the removed main speaker array up on top of the main circuit board.
    FixBot'a Sor
    Yorum Ekle
  9. Sonos Playbase IR Reciver Replacement, IR Receiver: adım 9, 3 resimden 1. Sonos Playbase IR Reciver Replacement, IR Receiver: adım 9, 3 resimden 2. Sonos Playbase IR Reciver Replacement, IR Receiver: adım 9, 3 resimden 3.
    Pro Tech Toolkit
    $79.95
    • Lift the main speaker array to reveal the IR receiver underneath.
    • Remove the three 11 mm T-5 screws by turning counter-clockwise.
    FixBot'a Sor
    Yorum Ekle
  10. Sonos Playbase IR Reciver Replacement: adım 10, 3 resimden 1. Sonos Playbase IR Reciver Replacement: adım 10, 3 resimden 2. Sonos Playbase IR Reciver Replacement: adım 10, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  11. Sonos Playbase IR Reciver Replacement: adım 11, 2 resimden 1. Sonos Playbase IR Reciver Replacement: adım 11, 2 resimden 2.
    • Remove the IR receiver by grasping it with two fingers and pulling up.
    FixBot'a Sor
    Yorum Ekle
Sonuç
George Slivka
341 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G2, White Fall 2018 Cal Poly, Team S17-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 1,727
