Ana içeriğe geç
Sonos Playbase Optical Audio Port Replacement
Neye ihtiyacın var
  1. Sonos Playbase Optical Audio Port Replacement, Bottom Panel: adım 1, 3 resimden 1. Sonos Playbase Optical Audio Port Replacement, Bottom Panel: adım 1, 3 resimden 2. Sonos Playbase Optical Audio Port Replacement, Bottom Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Pro Tech Toolkit
    $79.95
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  2. Sonos Playbase Optical Audio Port Replacement: adım 2, 2 resimden 1. Sonos Playbase Optical Audio Port Replacement: adım 2, 2 resimden 2.
    Pro Tech Toolkit
    $79.95
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
    FixBot'a Sor
    Yorum Ekle
  3. Sonos Playbase Optical Audio Port Replacement: adım 3, 2 resimden 1. Sonos Playbase Optical Audio Port Replacement: adım 3, 2 resimden 2.
    Pro Tech Toolkit
    $79.95
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
    FixBot'a Sor
    Yorum Ekle
  4. Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: adım 4, 2 resimden 1. Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: adım 4, 2 resimden 2.
    • Unplug the optical audio port from the main circuit board by pinching the white clip and pulling upward.
    FixBot'a Sor
    Yorum Ekle
  5. Sonos Playbase Optical Audio Port Replacement: adım 5, 2 resimden 1. Sonos Playbase Optical Audio Port Replacement: adım 5, 2 resimden 2.
    • Remove the three 38mm T-55 screws preventing you from removing the Optical Audio Port screws by turning them counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  6. Sonos Playbase Optical Audio Port Replacement: adım 6, 2 resimden 1. Sonos Playbase Optical Audio Port Replacement: adım 6, 2 resimden 2.
    Pro Tech Toolkit
    $79.95
    • Remove the two 18mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  7. Sonos Playbase Optical Audio Port Replacement: adım 7, 2 resimden 1. Sonos Playbase Optical Audio Port Replacement: adım 7, 2 resimden 2.
    • Remove the Optical Audio Port from the housing by pinching the sides and pulling outward.
    FixBot'a Sor
    Yorum Ekle
Sonuç
James Andrews
423 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G2, White Fall 2018 Cal Poly, Team S17-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S17G2
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Thank you for this guide, but any idea where to purchase a replacement optical audio port from?
donovanclarkson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 2,943
