Ana içeriğe geç
Sony α6000 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony α6000 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Remove the two 1.75mm Phillips #00 screws located on the bottom border of the LCD screen.
  2. Sony α6000 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the two 1.75mm Phillips #00 screws located on the back side of the LCD screen.
  3. Sony α6000 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Carefully separate the bottom border of the frame from the back surface of the LCD screen.
  4. Sony α6000 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the silver shield from the back side of the LCD screen.
  5. Sony α6000 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the smaller bracket covering the bottom portion of the control board.
  6. Sony α6000 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Carefully remove the spacer from behind the LCD screen.
  7. Sony α6000 LCD Screen Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Detach the ribbon from the socket with a pair of tweezers.
  8. Sony α6000 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Pull the LCD screen away from the camera and set aside.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rohn Albertson
635 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Summer 2019 IUPUI, Team S2-G2, Harley Summer 2019 üyesi
IUPUI-HARLEY-SU19S2G2
3 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Step 2 makes this repair impossible, the LCD screen is stuck at an angle where it's impossible to get a normal Phillips onto it without stripping the screw. Horribly inaccurate picture of how 'easy' it is to put the screwdriver there. Don't follow this guide.
Rawr Peng - Yanıt
Saw a bran new a6000 screen on eBay. So, I thought it would be easy to replace the scratched screen from my a6000. WOW was I wrong!
First I would say that step 2 is very hard to accomplish without stripping the screw. You need to pry the screen to get to an angle where it's doable. On my first attempt I striped the screw. I tried it on a second a6000 and successfully could remove the screw.
As it wasn't evident to me at first, I think it's important to specify that on step 7 you need to lift carefully the little black flap on the zero insertion force cable connector to unlock it. It's weak and I feel like it would be very prone to breaking.
What is NOT showed on this guide is what comes AFTER step 8! The screen is actually in a plastic frame That does not ship with the replacement screen and this frame is glued! So unless you have plastic glue and are able to unglue it first, you should NOT attempt this repair.
Consequently, I reassembled everything and have resigned myself to living with the scratchs.
Drgonz0 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 34
Son 30 gün: 127
Her zaman: 6,281
