Ana içeriğe geç
Sony α6000 Motherboard Replacement
Neye ihtiyacın var
  1. Sony α6000 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Sony α6000 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Motherboard Replacement: adım 2, 2 resimden 1. Sony α6000 Motherboard Replacement: adım 2, 2 resimden 2.
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Motherboard Replacement: adım 3, 2 resimden 1. Sony α6000 Motherboard Replacement: adım 3, 2 resimden 2.
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Motherboard Replacement: adım 4, 2 resimden 1. Sony α6000 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the battery.
  5. Sony α6000 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the 1.75mm Phillips #00 screw from the left side of the camera.
  6. Sony α6000 Motherboard Replacement: adım 6, 2 resimden 1. Sony α6000 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the two 1.75mm Phillips #00 screws from inside the battery department.
  7. Sony α6000 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the 1.75mm screw using a Phillips #00 head from underneath the flash.
  8. Sony α6000 Motherboard Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully remove the ribbon of the flash from the socket by using a pair of tweezers.
    • The best known method to removing the ribbon is to use a pair of tweezers with a rubber tip. This will help to prevent damage to the ribbon.
  9. Sony α6000 Motherboard Replacement: adım 9, 1 resimden 1.
    • The top of the camera will be free and can be removed.
    • Set the top of the camera to the side.
  10. Sony α6000 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the three 1.75mm Phillips #00 screws just below the eye sensor.
  11. Sony α6000 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the 1.75mm Phillips #00 screw from underneath the SD card cover.
  12. Sony α6000 Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove two 1.75mm Phillips #00 screws from the bottom of the camera.
  13. Sony α6000 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the 1.25mm screw from the right side underneath the battery cover.
  14. Sony α6000 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the 1.75mm Phillips #00 screw just to the right of the eye sensor.
  15. Sony α6000 Motherboard Replacement: adım 15, 1 resimden 1.
    • Set the eye sensor aside.
  16. Sony α6000 Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove the back panel of the camera.
  17. Sony α6000 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the two 1.25mm Phillips #00 screws near the top of the camera, just to the left of the eye socket.
  18. Sony α6000 Motherboard Replacement: adım 18, 1 resimden 1.
    • Remove the two 1.75mm Phillips #00 screws from the bottom of the camera.
  19. Sony α6000 Motherboard Replacement: adım 19, 1 resimden 1.
    • Remove the three 1.75mm Phillips #00 screws from the right side of the camera.
  20. Sony α6000 Motherboard Replacement: adım 20, 1 resimden 1.
    • Remove one ribbon that is attached to the selector wheel with a pair of tweezers.
  21. Sony α6000 Motherboard Replacement: adım 21, 1 resimden 1.
    • lift up the protector plate and remove one ribbon that is attached to the LCD screen with a pair of tweezers.
  22. Sony α6000 Motherboard Replacement: adım 22, 1 resimden 1.
    • Detach the LCD screen from the back portion of the camera and set it aside.
  23. Sony α6000 Motherboard Replacement: adım 23, 1 resimden 1.
    • Lift up the black cover to reveal the motherboard and ten ribbons.
    • With a pair of tweezers separate the ribbons from the motherboard by pulling them out of their sockets.
  24. Sony α6000 Motherboard Replacement: adım 24, 1 resimden 1.
    • Remove the four 1.25mm Phillips #00 screws located on the borders of the motherboard.
  25. Sony α6000 Motherboard Replacement: adım 25, 1 resimden 1.
    • Remove the power supply at the bottom right hand corner with a pair of tweezers.
  26. Sony α6000 Motherboard Replacement: adım 26, 1 resimden 1.
    • Lift the motherboard up and remove the last ribbon cable with a pair of tweezers.
  27. Sony α6000 Motherboard Replacement: adım 27, 1 resimden 1.
    • Remove the motherboard and set aside.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rohn Albertson
635 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Summer 2019 IUPUI, Team S2-G2, Harley Summer 2019 üyesi
IUPUI-HARLEY-SU19S2G2
3 Üyeler
6 adet Kılavuz yazıldı
3 Yorum
I have been wondering what path I will take when I replace my battery contacts part and this looks like an ideal guide for how I can do it. I wondered why you don’t discharge the capacitor before removing ribbon cables. When I removed the top block off my nex-6 I did discharge the capacitor as what the service manual suggested before I removed the control dial and flash ribbon cables. Before I did it I found a youtube about using wires to the discharge contacts going to a light bulb to safely discharge the capacitor. The service manual suggests using a short jig R:1 k Ω/1 W but since I don’t have access to an electronics store nearby the youtube did the trick trouble free.
georgevp1 - Yanıt
I was successful with the dissembling the camera and will need to invest in a working logic board and maybe something that is part of the shutter. I was hoping the camera would be an easy fix but sometimes this isn’t this case.
georgevp1 - Yanıt
is there a way to fix the hdmi out port without buying a new mother board?
Nicholas Costanza - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 73
Her zaman: 4,421
