Neye ihtiyacın var
Remove the two screws on the bottom of the camera.
Remove the screw inside the battery door.
Once these are removed, slide the door out, and the small piece of plastic with the door.
Grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
You'll see a screw on the top of the device, towards the front, remove this screw.
Pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
