Ana içeriğe geç
Sony Action Cam HDR-AS15 Speaker Removal
Neye ihtiyacın var
  1. Sony Action Cam HDR-AS15 Speaker Removal, Sony Action Cam HDR-AS15 Speaker Removal: adım 1, 2 resimden 1. Sony Action Cam HDR-AS15 Speaker Removal, Sony Action Cam HDR-AS15 Speaker Removal: adım 1, 2 resimden 2.
    • Remove battery. Open bottom hatch. Remove the 2x screws with mini philips driver, the bottom hatch door should just come out with a little pull now.
  2. Sony Action Cam HDR-AS15 Speaker Removal: adım 2, 2 resimden 1. Sony Action Cam HDR-AS15 Speaker Removal: adım 2, 2 resimden 2.
    • Gently press the tab in the center as you slide out the electronics.
  3. Sony Action Cam HDR-AS15 Speaker Removal: adım 3, 2 resimden 1. Sony Action Cam HDR-AS15 Speaker Removal: adım 3, 2 resimden 2.
    • Remove 2x screws over the metal retaining clip; one is above the LCD and one is below. Gently pull the plastic tab at the top as you swing the metal retaining clip downward. Desolder the speaker. Replace the metal retaining clip and 2x screws.
  4. Sony Action Cam HDR-AS15 Speaker Removal: adım 4, 1 resimden 1.
    • Slide electronics back into the housing. Replace bottom port cover and 2x screws. Replace battery. Cut tether to the bottom hatch, replace on bottom of camera.
Sonuç
Enjoy silent operation and hassle-free access to the ports!
Even Easier: you can skip some steps if you just clip one of the wires to the speaker (red or blue), and leave the speaker in the unit.
2 farklı kişi bu kılavuzu tamamladı.
joseph
136 İtibar
1 Kılavuz yazıldı
5 Yorum
Nice. Now how about making it easier to attach a remote microphone? One should be able to pull out or connect a pigtail to the 3mm jack and make a dongle outside the case, no? :)
flyrv9 - Yanıt
The other way is to turn off the sound through the setup menu….
edward - Yanıt
I came here to say what edward said :P
Although you have to upgrade the firmware first, I think...
ahahah -
Wow, good pics. Seems you don't even need the (dis-)assembly guide I just found: http://elektrotanya.com/sony_hdr-as15_le...
:-D
wwwaste - Yanıt
Where can I find sony action cam parts, I need some for the bottom of this cam....ANY LINKS OR SITES...Thank U
usbreaks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 2,998
