Ana içeriğe geç
Sony Action Cam Mini HDR-AZ1 Battery Door Replacement
Neye ihtiyacın var
  1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: adım 1, 3 resimden 1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: adım 1, 3 resimden 2. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: adım 1, 3 resimden 3.
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: adım 2, 3 resimden 1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: adım 2, 3 resimden 2. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: adım 2, 3 resimden 3.
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
  3. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: adım 3, 2 resimden 1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: adım 3, 2 resimden 2.
    • Remove the circled 4 millimeter black screw adjacent to where the door is attached.
  4. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: adım 4, 2 resimden 1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: adım 4, 2 resimden 2.
    • Grab the small black bracket holding the ribbon on which the door is attached and pull it out.
  5. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: adım 5, 1 resimden 1.
    • Pull the door straight back so the attaching ribbon is pulled taught and the door will come right off.
Sonuç
Mathieu LaFond
425 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G7
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 743
