Ana içeriğe geç
Sony Action Cam Mini HDR-AZ1 Gasket Replacement
Neye ihtiyacın var
  1. Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: adım 1, 2 resimden 1. Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: adım 1, 2 resimden 2.
    • To open the case, slide the tab located on the underside of the case to the “unlock” position.
    • Press in the tabs, that are on the sides of the unlock tab, and pull down. This should cause the lid to open.
    • Remove the lid.
  2. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, wedge it between the O-Ring and the groove.
    • Move the tool around the ring, prying the gasket from the groove, until it is able to be grabbed.
  3. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: adım 3, 1 resimden 1.
    • Remove the O-Ring from the lid of the case.
Sonuç
To place a new gasket in, follow these steps in reverse order, making sure the gasket is fully pushed back in around its entire perimeter.
Mathieu LaFond
425 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G7
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 589
