Ana içeriğe geç
Sony Alpha 5100 Front Plate Replacement
  1. Sony Alpha 5100 Front Plate Replacement, Battery: adım 1, 2 resimden 1. Sony Alpha 5100 Front Plate Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the power switch on the top of the camera to "off."
    • Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
  2. Sony Alpha 5100 Front Plate Replacement: adım 2, 1 resimden 1.
    • Push the blue spring-loaded lever to release the battery.
    • Remove the battery from the camera.
  3. Sony Alpha 5100 Front Plate Replacement, Front Plate: adım 3, 3 resimden 1. Sony Alpha 5100 Front Plate Replacement, Front Plate: adım 3, 3 resimden 2. Sony Alpha 5100 Front Plate Replacement, Front Plate: adım 3, 3 resimden 3.
    • Remove one 2mm Phillips #00 screw from the flash plate cover.
    • Use the spudger to pop the plate off.
    • Remove two 2mm Phillips #00 screws on the side of the camera.
  4. Sony Alpha 5100 Front Plate Replacement: adım 4, 2 resimden 1. Sony Alpha 5100 Front Plate Replacement: adım 4, 2 resimden 2.
    • Pop the memory card door open by gently lifting the door up.
    • Remove two 2mm Phillips #00 screws from the side of the camera.
    • Remove three 2mm Phillips #00 screws on the bottom of the camera.
  5. Sony Alpha 5100 Front Plate Replacement: adım 5, 2 resimden 1. Sony Alpha 5100 Front Plate Replacement: adım 5, 2 resimden 2.
    • Use the opening tool to gently pop the front plate apart from the body.
Sonuç
Kevin Raggiani
444 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 UMass Dartmouth, Team S4-G6, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G6
3 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
Hi, i need to access the shutter-on/off switch on my a5100. Which parts and screws do i need to take apart.?
Thank you,
Fabian,
Fabian - Yanıt
Step 4 is missing one screw. Pop the flash and there is a screw there sideways that must come out.
Nick P - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 32
Her zaman: 1,540
