Giriş
Use this guide to replace the front plate on the Sony Alpha 5100 (or Sony a5100).
Always use CAUTION when self-repairing and follow the instructions closely to avoid potential damage to the device.
Slide the power switch on the top of the camera to "off."
Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
Remove one 2mm Phillips #00 screw from the flash plate cover.
Use the spudger to pop the plate off.
Remove two 2mm Phillips #00 screws on the side of the camera.
