Ana içeriğe geç
Sony Alpha 5100 Lens Replacement
  1. Sony Alpha 5100 Lens Replacement, Lens: adım 1, 1 resimden 1.
    • Place the camera in front so the lens is facing you. There should be a small button on the bottom left side of the lens.
  2. Sony Alpha 5100 Lens Replacement: adım 2, 1 resimden 1.
    • While holding down the button with your left thumb, use your right hand to twist the lens counterclockwise.
    • Make sure that you are twisting the bottom end of the lens.
  3. Sony Alpha 5100 Lens Replacement: adım 3, 1 resimden 1.
    • To insert a new lens, align the marking on the lens to the marking on the mount on the camera body.
    • Once insert correctly, you can twist the lens in clockwise direction easily until it clicks.
Sonuç
Quang Phan
97 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 UMass Dartmouth, Team S4-G6, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G6
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,249
