Ana içeriğe geç
Sony Alpha 6000 Screen Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Sony Alpha 6000 Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the camera is turned off by turning the switch to OFF.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha 6000 Screen Replacement: adım 2, 1 resimden 1.
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha 6000 Screen Replacement: adım 3, 1 resimden 1.
      • Locate the blue latch that holds the battery in.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Alpha 6000 Screen Replacement: adım 4, 1 resimden 1.
      • Push the latch back to release battery.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Alpha 6000 Screen Replacement: adım 5, 1 resimden 1.
      • The battery can now be taken out of its compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Alpha 6000 Screen Replacement, Screen: adım 6, 2 resimden 1. Sony Alpha 6000 Screen Replacement, Screen: adım 6, 2 resimden 2.
      • Locate and unscrew the two 3 mm screws on the bottom of the screen.
      • Pull the screen out from the top to reveal the two screws behind the screen; unscrew the two 3 mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha 6000 Screen Replacement: adım 7, 3 resimden 1. Sony Alpha 6000 Screen Replacement: adım 7, 3 resimden 2. Sony Alpha 6000 Screen Replacement: adım 7, 3 resimden 3.
      • Flip the screen so it is facing up and then have the bottom of the camera facing yourself.
      • Using a spudger, remove the larger back panel.
      • Flip the camera right side up and pull back the screen.
      • Remove the smaller black panel on the back of the screen.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha 6000 Screen Replacement: adım 8, 2 resimden 1. Sony Alpha 6000 Screen Replacement: adım 8, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Locate the small "H" shaped clip on the back of the screen.
      • Remove the clip with tweezers
      FixBot'a Sor
      Yorum Ekle
    4. Sony Alpha 6000 Screen Replacement: adım 9, 3 resimden 1. Sony Alpha 6000 Screen Replacement: adım 9, 3 resimden 2. Sony Alpha 6000 Screen Replacement: adım 9, 3 resimden 3.
      • Flip the screen back so it is facing up and then have the bottom of the camera facing you. The yellow circuit board should now be exposed.
      • Hold down the yellow circuit board that the ribbon cables are attached to.
      • Using tweezers, remove the smaller ribbon cable. This may require extra force that could damage the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Alpha 6000 Screen Replacement: adım 10, 2 resimden 1. Sony Alpha 6000 Screen Replacement: adım 10, 2 resimden 2.
      • Remove the larger ribbon cable. This may require extra force that could damage the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    6. Sony Alpha 6000 Screen Replacement: adım 11, 2 resimden 1. Sony Alpha 6000 Screen Replacement: adım 11, 2 resimden 2.
      • Using a plastic opening tool, separate the silver panel from the actual screen.
      • Carefully slide the ribbon cables through the narrow opening to fully remove the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Now your screen is ready to be replaced! To reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Jennifer Vuu
548 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-5, Passmore Fall 2016 USF Tampa, Team 4-5, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G5
3 Üyeler
40 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 1,794
