Ana içeriğe geç
Sony Alpha 6000 Setting Wheel Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Sony Alpha 6000 Setting Wheel Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the camera is turned off by turning the switch to OFF.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha 6000 Setting Wheel Replacement: adım 2, 1 resimden 1.
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha 6000 Setting Wheel Replacement: adım 3, 1 resimden 1.
      • Locate the blue latch that holds the battery in.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Alpha 6000 Setting Wheel Replacement: adım 4, 1 resimden 1.
      • Push the latch back to release battery.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Alpha 6000 Setting Wheel Replacement: adım 5, 1 resimden 1.
      • The battery can now be taken out of its compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Alpha 6000 Setting Wheel Replacement, Back Cover: adım 6, 1 resimden 1.
      • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha 6000 Setting Wheel Replacement: adım 7, 1 resimden 1.
      • Turn the camera sideways.
      • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
      • Unscrew using the J00 head screw.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha 6000 Setting Wheel Replacement: adım 8, 1 resimden 1.
      • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Alpha 6000 Setting Wheel Replacement: adım 9, 1 resimden 1.
      • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
      • Locate them and unscrew them.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Alpha 6000 Setting Wheel Replacement: adım 10, 2 resimden 1. Sony Alpha 6000 Setting Wheel Replacement: adım 10, 2 resimden 2.
      • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
      • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Alpha 6000 Setting Wheel Replacement, Setting Wheel: adım 11, 3 resimden 1. Sony Alpha 6000 Setting Wheel Replacement, Setting Wheel: adım 11, 3 resimden 2. Sony Alpha 6000 Setting Wheel Replacement, Setting Wheel: adım 11, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Once the back cover is removed, using tweezers, pull to remove the ribbon cable that is holding the settings wheel.
      • Now you can pull the settings wheel out of the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To put the camera back together, follow these steps in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
Fernando Sierra
400 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-5, Passmore Fall 2016 USF Tampa, Team 4-5, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G5
3 Üyeler
48 adet Kılavuz yazıldı
4Kılavuz Yorumları
I am trying to remove the back so I can remove the USB cover and hing as the cover is broke. If I fallow these instructions will I get to that pin?
Nate - Yanıt Paylaş
Quiet nice instructions… but you are missing a few important steps which are necessary to avoid damage:
1) You forget to mention the 3rd screw at the entry of the battery compartment.. in your picture of step 8 it is allready loose. It is not possible to remove the back panel without loosening of that screw.
2) It is much easier to remove the back panel, if you lift up the top panel, therefor you should loosen the two J00 screws under the internal flash.
3) You forget to mention that there needs to be a screw removed at the “dioptre correction wheel”, therefor the central small rubber patch needs to be removed with tweezers, then the underlying J00 can be unscrewed and the “dioptre correction wheel” removed.
4) Once the back panel has then carefully be loosened with a plastic opening tool you should be able to remove an additional screw of the eyepiece (right side), so that the eyepiece cover can be lift off, and then the backpanel is much easier to be removed.
Look for youtube “Dissasembly A6000”!
Torsten S. - Yanıt Paylaş
Half of the steps are missing! This kind of tutorials are not helpful. Actually they are counterproductive and lead to broken devices. There is a great Youtube video of how to disassamble the Sony Alpha 6000.
guillermo - Yanıt Paylaş
AVOID THIS GUIDE! There are several steps missing!!! YOU?LL BROKE THE CAMERA IF YOU FOLLOW JUST THESE STEPS!
Daniele Fior - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 30
Son 30 gün: 152
Her zaman: 14,176
