Ana içeriğe geç
Sony Alpha 6000 Shutter Button Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Sony Alpha 6000 Shutter Button Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the camera is turned off by turning the switch to OFF.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha 6000 Shutter Button Replacement: adım 2, 1 resimden 1.
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha 6000 Shutter Button Replacement: adım 3, 1 resimden 1.
      • Locate the blue latch that holds the battery in.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Alpha 6000 Shutter Button Replacement: adım 4, 1 resimden 1.
      • Push the latch back to release battery.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Alpha 6000 Shutter Button Replacement: adım 5, 1 resimden 1.
      • The battery can now be taken out of its compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Alpha 6000 Shutter Button Replacement, Back Cover: adım 6, 1 resimden 1.
      • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha 6000 Shutter Button Replacement: adım 7, 1 resimden 1.
      • Turn the camera sideways.
      • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
      • Unscrew using the J00 head screw.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha 6000 Shutter Button Replacement: adım 8, 1 resimden 1.
      • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Alpha 6000 Shutter Button Replacement: adım 9, 1 resimden 1.
      • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
      • Locate them and unscrew them.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Alpha 6000 Shutter Button Replacement: adım 10, 2 resimden 1. Sony Alpha 6000 Shutter Button Replacement: adım 10, 2 resimden 2.
      • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
      • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: adım 11, 1 resimden 1.
      • Once the back cover is off, locate the flash of the camera and push it forward to open it
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha 6000 Shutter Button Replacement: adım 12, 1 resimden 1.
      • Locate the two 3 mm screws within the flash and unscrew them
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha 6000 Shutter Button Replacement: adım 13, 1 resimden 1.
      • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Alpha 6000 Shutter Button Replacement: adım 14, 2 resimden 1. Sony Alpha 6000 Shutter Button Replacement: adım 14, 2 resimden 2.
      • Hold the top of the camera away from the body.
      • Carefully turn it over to uncover the bottom of the shutter button.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Alpha 6000 Shutter Button Replacement: adım 15, 1 resimden 1.
      • Locate the two screws holding the shutter button and unscrew them.
      FixBot'a Sor
      Yorum Ekle
    6. Sony Alpha 6000 Shutter Button Replacement: adım 16, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
      FixBot'a Sor
      Yorum Ekle
    7. Sony Alpha 6000 Shutter Button Replacement: adım 17, 1 resimden 1.
      • Turn the top plastic piece back over.
      • Now you will be able to completely remove the camera's shutter button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
7 farklı kişi bu kılavuzu tamamladı.
Fernando Sierra
400 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-5, Passmore Fall 2016 USF Tampa, Team 4-5, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G5
3 Üyeler
48 adet Kılavuz yazıldı
4Kılavuz Yorumları
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - Yanıt Paylaş
Where can i buy a replacement button?
Simon Lundh - Yanıt Paylaş
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster - Yanıt Paylaş
Thank you!
Arshad kltn - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 37
Son 30 gün: 171
Her zaman: 20,130
