Ana içeriğe geç
Sony Alpha A3000 Motherboard Replacement
Neye ihtiyacın var
    1. Sony Alpha A3000 Motherboard Replacement, Rear Case: adım 1, 3 resimden 1. Sony Alpha A3000 Motherboard Replacement, Rear Case: adım 1, 3 resimden 2. Sony Alpha A3000 Motherboard Replacement, Rear Case: adım 1, 3 resimden 3.
      • Remove the seven highlighted screws shown here.
      • Screws are teeny tiny, don't lose them!
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha A3000 Motherboard Replacement: adım 2, 2 resimden 1. Sony Alpha A3000 Motherboard Replacement: adım 2, 2 resimden 2.
      • Remove this final screw from the memory card compartment.
      • Remove the chassis by pulling the back cover away from the camera.
      • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha A3000 Motherboard Replacement: adım 3, 2 resimden 1. Sony Alpha A3000 Motherboard Replacement: adım 3, 2 resimden 2.
      • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Alpha A3000 Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Sony Alpha A3000 Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
      • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
      • Detach the facing for the memory dock.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha A3000 Motherboard Replacement: adım 5, 2 resimden 1. Sony Alpha A3000 Motherboard Replacement: adım 5, 2 resimden 2.
      • Remove the eight screws securing the mount for the flash device.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha A3000 Motherboard Replacement: adım 6, 2 resimden 1. Sony Alpha A3000 Motherboard Replacement: adım 6, 2 resimden 2.
      • Remove the three remaining screws holding in the protective metal casing.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Alpha A3000 Motherboard Replacement: adım 7, 1 resimden 1.
      • Remove the metal casing.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Alpha A3000 Motherboard Replacement: adım 8, 1 resimden 1.
      • Remove three screws holding down the motherboard .
      FixBot'a Sor
      Yorum Ekle
    6. Sony Alpha A3000 Motherboard Replacement: adım 9, 2 resimden 1. Sony Alpha A3000 Motherboard Replacement: adım 9, 2 resimden 2.
      • Detach the nine serial cables connecting it to the camera body.
      FixBot'a Sor
      Yorum Ekle
    7. Sony Alpha A3000 Motherboard Replacement: adım 10, 1 resimden 1.
      • Finally remove the motherboard from the casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Leonard Holloman
662 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Meier Fall 2015 USF Tampa, Team 4-4, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G4
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Then loose the plug all the motherboard?
kongre172 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 44
Her zaman: 3,210
