Ana içeriğe geç
Sony Alpha A350 Front Case Replacement
Neye ihtiyacın var
  1. Sony Alpha A350 Front Case Replacement, Front Case: adım 1, 2 resimden 1. Sony Alpha A350 Front Case Replacement, Front Case: adım 1, 2 resimden 2.
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
  2. Sony Alpha A350 Front Case Replacement: adım 2, 2 resimden 1. Sony Alpha A350 Front Case Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
  3. Sony Alpha A350 Front Case Replacement: adım 3, 2 resimden 1. Sony Alpha A350 Front Case Replacement: adım 3, 2 resimden 2.
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
  4. Sony Alpha A350 Front Case Replacement: adım 4, 2 resimden 1. Sony Alpha A350 Front Case Replacement: adım 4, 2 resimden 2.
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
  5. Sony Alpha A350 Front Case Replacement: adım 5, 2 resimden 1. Sony Alpha A350 Front Case Replacement: adım 5, 2 resimden 2.
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
Sonuç
Danielle Trivett
337 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Henning Fall 2019 IUPUI, Team S1-G6, Henning Fall 2019 üyesi
IUPUI-HENNING-F19S1G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 893
