Ana içeriğe geç
Sony Alpha DSLR- A850 Viewfinder Window Replacement
Neye ihtiyacın var
  1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Cover: adım 1, 1 resimden 1.
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: adım 2, 1 resimden 1.
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: adım 3, 1 resimden 1.
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
  4. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: adım 4, 2 resimden 1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: adım 4, 2 resimden 2.
    • Remove all four screws from the viewfinder.
  5. Sony Alpha DSLR- A850 Viewfinder Window Replacement: adım 5, 2 resimden 1. Sony Alpha DSLR- A850 Viewfinder Window Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Grasp the side of the window with either a set of tweezers or your fingers. Lift upwards and slightly towards the base of the camera.
  6. Sony Alpha DSLR- A850 Viewfinder Window Replacement: adım 6, 1 resimden 1.
    • To reinsert the window, push inward and slightly forward. There is a tab on the camera that the window must catch on in order to be put into place.
Sonuç
Richard Fabian
256 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 396
