Ana içeriğe geç
Sony Alpha ILCE-6000 E-mount Replacement
Neye ihtiyacın var
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: adım 1, 1 resimden 1.
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: adım 2, 1 resimden 1.
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: adım 3, 2 resimden 1. Sony Alpha ILCE-6000 E-mount Replacement: adım 3, 2 resimden 2.
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: adım 4, 2 resimden 1. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: adım 4, 2 resimden 2.
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: adım 5, 3 resimden 1. Sony Alpha ILCE-6000 E-mount Replacement: adım 5, 3 resimden 2. Sony Alpha ILCE-6000 E-mount Replacement: adım 5, 3 resimden 3.
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: adım 6, 3 resimden 1. Sony Alpha ILCE-6000 E-mount Replacement: adım 6, 3 resimden 2. Sony Alpha ILCE-6000 E-mount Replacement: adım 6, 3 resimden 3.
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: adım 7, 1 resimden 1.
    • Replace the plastic E-mount ring with a new one.
Sonuç
Yirga Yilma
251 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-4, Rose Winter 2017 UW Tacoma, Team 1-4, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G4
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - Yanıt
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 29
Son 30 gün: 72
Her zaman: 4,150
