Ana içeriğe geç
Sony Alpha NEX-3N LCD assembly Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: adım 1, 2 resimden 1. Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: adım 1, 2 resimden 2.
    • Remove battery and card
  2. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: adım 2, 3 resimden 1. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: adım 2, 3 resimden 2. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: adım 2, 3 resimden 3.
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 2: adım 3, 1 resimden 1.
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: adım 4, 3 resimden 1. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: adım 4, 3 resimden 2. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: adım 4, 3 resimden 3.
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: adım 5, 2 resimden 1. Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: adım 5, 2 resimden 2.
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: adım 6, 3 resimden 1. Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: adım 6, 3 resimden 2. Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: adım 6, 3 resimden 3.
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N LCD assembly Replacement, The LCD assembly: adım 7, 1 resimden 1.
    • The LCD assembly
  8. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: adım 8, 3 resimden 1. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: adım 8, 3 resimden 2. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: adım 8, 3 resimden 3.
    • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
    • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
  9. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: adım 9, 3 resimden 1. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: adım 9, 3 resimden 2. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: adım 9, 3 resimden 3.
    • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
    • the the circle marker that show others ribbon you need to be carefull. goodluck!
Sonuç
Terrance
6.455 İtibar
17 adet Kılavuz yazıldı
2 Yorum
Where can i get a lcd screen replacement?
Searched everywhere even AliExpress they do not sell the replacement lcd for this model
adfa dad - Yanıt
No idea. I broke 2 FPC and lost some lens contact springs, got no where to buy, planning to replace the FPCs, but too busy these days .........
Terrance -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 116
Her zaman: 1,637
