Ana içeriğe geç
Sony Alpha NEX-3N Mainboard Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-3N Mainboard Replacement, Getting Started: adım 1, 2 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, Getting Started: adım 1, 2 resimden 2.
    • Remove battery and card
  2. Sony Alpha NEX-3N Mainboard Replacement, Back Case 1: adım 2, 3 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, Back Case 1: adım 2, 3 resimden 2. Sony Alpha NEX-3N Mainboard Replacement, Back Case 1: adım 2, 3 resimden 3.
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N Mainboard Replacement, Back Case 2: adım 3, 1 resimden 1.
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N Mainboard Replacement, Back Case 3: adım 4, 3 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, Back Case 3: adım 4, 3 resimden 2. Sony Alpha NEX-3N Mainboard Replacement, Back Case 3: adım 4, 3 resimden 3.
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N Mainboard Replacement, LCD assembly: adım 5, 2 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, LCD assembly: adım 5, 2 resimden 2.
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N Mainboard Replacement, LCD Assembly: adım 6, 3 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, LCD Assembly: adım 6, 3 resimden 2. Sony Alpha NEX-3N Mainboard Replacement, LCD Assembly: adım 6, 3 resimden 3.
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N Mainboard Replacement, The LCD assembly: adım 7, 1 resimden 1.
    • The LCD assembly
  8. Sony Alpha NEX-3N Mainboard Replacement, Dismantle the LCD Part: adım 8, 3 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, Dismantle the LCD Part: adım 8, 3 resimden 2. Sony Alpha NEX-3N Mainboard Replacement, Dismantle the LCD Part: adım 8, 3 resimden 3.
    • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
    • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
  9. Sony Alpha NEX-3N Mainboard Replacement, Dismantle the LCD Part: adım 9, 3 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, Dismantle the LCD Part: adım 9, 3 resimden 2. Sony Alpha NEX-3N Mainboard Replacement, Dismantle the LCD Part: adım 9, 3 resimden 3.
    • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
    • the the circle marker that show others ribbon you need to be carefull. goodluck!
  10. Sony Alpha NEX-3N Mainboard Replacement, Keypad: adım 10, 3 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, Keypad: adım 10, 3 resimden 2. Sony Alpha NEX-3N Mainboard Replacement, Keypad: adım 10, 3 resimden 3.
    • Lift the keypad.
    • Detach FPC
  11. Sony Alpha NEX-3N Mainboard Replacement, Screws: adım 11, 1 resimden 1.
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  12. Sony Alpha NEX-3N Mainboard Replacement: adım 12, 2 resimden 1. Sony Alpha NEX-3N Mainboard Replacement: adım 12, 2 resimden 2.
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  13. Sony Alpha NEX-3N Mainboard Replacement: adım 13, 1 resimden 1.
    • Remove that part whatever called, by sliding it backwards.
  14. Sony Alpha NEX-3N Mainboard Replacement, Screws: adım 14, 3 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, Screws: adım 14, 3 resimden 2. Sony Alpha NEX-3N Mainboard Replacement, Screws: adım 14, 3 resimden 3.
    • 1 ST1.7x5
    • 2 ST1.7x5
    • 1 M1.4x3.6 black
  15. Sony Alpha NEX-3N Mainboard Replacement, The Grip: adım 15, 2 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, The Grip: adım 15, 2 resimden 2.
    • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
    • Pop the grip off. From back, push to the right, then it flies forward.
  16. Sony Alpha NEX-3N Mainboard Replacement, More Screws: adım 16, 1 resimden 1.
    • Remove 2 M1.4x2 black screws
  17. Sony Alpha NEX-3N Mainboard Replacement, Pop the Shielding Cover: adım 17, 2 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, Pop the Shielding Cover: adım 17, 2 resimden 2.
    • with caution and patient.
  18. Sony Alpha NEX-3N Mainboard Replacement, One More Shield: adım 18, 3 resimden 1. Sony Alpha NEX-3N Mainboard Replacement, One More Shield: adım 18, 3 resimden 2. Sony Alpha NEX-3N Mainboard Replacement, One More Shield: adım 18, 3 resimden 3.
    • 1 M1.4x3.6
  19. Sony Alpha NEX-3N Mainboard Replacement, Detach 7000 FPCs: adım 19, 1 resimden 1.
    • Sensor power, flip
    • Sensor signal, flip
    • Shutter, pull
    • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
    • Whatever, pull
    • Whatever, pull
    • Shutter charger motor FPC, (backside, pull out)
  20. Sony Alpha NEX-3N Mainboard Replacement: adım 20, 1 resimden 1.
    • Flip the Mainboard up
    • Pull out one more FPC
    • Discharge then desolder 4 wires.
    • CAUTION! Possible high DC voltage >300V
  21. Sony Alpha NEX-3N Mainboard Replacement: adım 21, 1 resimden 1.
    • Lift main board and plastic frame with flash capacitor.
Sonuç
Terrance
6.455 İtibar
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 153
