Right side, remove 1 M1.4x3.7 screw
Left side, remove 3 M1.4x3.7 screws
Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
Remove LCD hinge cover, by sliding to the left.
Remove back cover, actually just a plastic frame.
Loosen LCD assemble with caution!
Release FPC cable, the connector is flip type.
After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
the the circle marker that show others ribbon you need to be carefull. goodluck!
Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
Pop the grip off. From back, push to the right, then it flies forward.
Sensor power, flip
Sensor signal, flip
Shutter, pull
Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
Whatever, pull
Whatever, pull
Shutter charger motor FPC, (backside, pull out)
Remove 3 ST1.7x5 screws
Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
Bir başkası bu kılavuzu tamamladı.
