Giriş
A glass screen protector replacement piece designated for a Sony NEX-5N is necessary to replace the current LCD screen protector. Air bubbles that develop below the screen will not disappear over time, but result in irreversible peeling. Replacing the LCD glass screen protector will enhance the display's visual clarity.
Neye ihtiyacın var
Find a firm, comfortable grip on the device with one hand, and apply pressure to the LCD screen, placing your fingers on the glass.
With your other hand (if the corners are not already peeling), utilize your fingernails to locate and pick at the most vulnerable corner of the LCD glass screen protector.
Bu adımda kullanılan alet:Tweezers$4.99
Slowly, to avoid ripping the protector or damaging the LCD touch screen beneath, peel the LCD glass screen protector back with your fingers, or a pair of tweezers, depending on what works best for you.
Continue peeling until the LCD protector is completely detached from the LCD touch screen.
6 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
hi. is there protector from factory? or is it your?
où peut - on acheter le film de protection de remplacement pour appareil photo Sony cyber- shotRX 100
