Ana içeriğe geç
Sony Alpha NEX-5N Lens Release Button Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-5N Lens Release Button Replacement, E-mount: adım 1, 2 resimden 1. Sony Alpha NEX-5N Lens Release Button Replacement, E-mount: adım 1, 2 resimden 2.
    • While completing this guide, do not touch the image sensor (the center rectangle encircled by the lens mount).
    • Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
    • Applying extra force to unscrew these 4 screws may be necessary.
    • Detach the outer lens mount ring.
  2. Sony Alpha NEX-5N Lens Release Button Replacement: adım 2, 2 resimden 1. Sony Alpha NEX-5N Lens Release Button Replacement: adım 2, 2 resimden 2.
    • Pay attention to the positioning and order of the spacing rings for reassembly.
    • Using your fingers, pull out the first black spacer ring.
    • Repeat the previous step for the second silver spacer ring.
  3. Sony Alpha NEX-5N Lens Release Button Replacement: adım 3, 3 resimden 1. Sony Alpha NEX-5N Lens Release Button Replacement: adım 3, 3 resimden 2. Sony Alpha NEX-5N Lens Release Button Replacement: adım 3, 3 resimden 3.
    • Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
    • Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
    • The lens release button and the small spring underneath will be loose.
  4. Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: adım 4, 3 resimden 1. Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: adım 4, 3 resimden 2. Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: adım 4, 3 resimden 3.
    • Find the lens release button.
    • The button should be easily removed by hand.
  5. Sony Alpha NEX-5N Lens Release Button Replacement: adım 5, 1 resimden 1.
    • After removing the button, the spring underneath it is uncovered and can be replaced.
    • This completes the removal of the lens release button.
Sonuç
Anna Tole
191 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
What to do if the lens is attached to the camera and the release button is stuck?
on a Nikon d7100.
ajbakh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 2,055
