Ana içeriğe geç
Sony Alpha NEX-6 Battery Replacement
Neye ihtiyacın var
    1. Sony Alpha NEX-6 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Alpha NEX-6 Battery Replacement: adım 2, 1 resimden 1.
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Alpha NEX-6 Battery Replacement: adım 3, 1 resimden 1.
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Clayton Dale
1.067 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G2
4 Üyeler
14 adet Kılavuz yazıldı
3Kılavuz Yorumları
Battery Stuck
rustychinnis - Yanıt Paylaş
Will not spring out. Any ideas?
Got it, battery damaged. Tapped on edge to remove battery
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 3,046
