Ana içeriğe geç
Sony Alpha NEX-6 Control Wheel Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-6 Control Wheel Replacement, Battery: adım 1, 1 resimden 1.
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Alpha NEX-6 Control Wheel Replacement: adım 2, 1 resimden 1.
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Alpha NEX-6 Control Wheel Replacement: adım 3, 1 resimden 1.
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Alpha NEX-6 Control Wheel Replacement, Battery compartment screws: adım 4, 1 resimden 1.
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Alpha NEX-6 Control Wheel Replacement, Bottom screws: adım 5, 1 resimden 1.
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Alpha NEX-6 Control Wheel Replacement, Side screws: adım 6, 1 resimden 1.
    • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
    • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: adım 7, 2 resimden 1. Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: adım 7, 2 resimden 2.
    • Starting with the battery compartment gently begin to separate the back case front the camera.
    • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
    • Gently lift the back case away from the camera an slide it down to completely remove the back case.
    FixBot'a Sor
    Yorum Ekle
  8. Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: adım 8, 2 resimden 1. Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: adım 8, 2 resimden 2.
    • Pry out the ribbon cable by carefully pushing on its side tabs with a spudger.
    FixBot'a Sor
    Yorum Ekle
  9. Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: adım 9, 2 resimden 1. Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a spudger, lift the metal locking tab located at the top right corner of control wheel assembly.
    • Using tweezers, carefully slide the assembly up to release it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Clayton Dale
1.067 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 61
Her zaman: 6,003
