Ana içeriğe geç
Sony Alpha NEX-6 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-6 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Alpha NEX-6 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Alpha NEX-6 LCD Screen Replacement: adım 3, 1 resimden 1.
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Alpha NEX-6 LCD Screen Replacement, Removing back screws: adım 4, 1 resimden 1.
    • Remove the two 1.0 mm Phillips #00 screws from back of the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Alpha NEX-6 LCD Screen Replacement, Removing bottom screws: adım 5, 1 resimden 1.
    • Remove the two 1.5 mm Phillips #00 screws from the bottom of the screen mount assembly.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Alpha NEX-6 LCD Screen Replacement, Back cover: adım 6, 2 resimden 1. Sony Alpha NEX-6 LCD Screen Replacement, Back cover: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a plastic opening tool pry off the back cover from the screen assembly.
    • Remove back cover by lifting it away from the screen using tweezers.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: adım 7, 3 resimden 1. Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: adım 7, 3 resimden 2. Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: adım 7, 3 resimden 3.
    • Release the ribbon cable by lifting the black locking latch with the plastic opening tool.
    • Pry out the ribbon cable by carefully sliding it out of the connection slot using a spudger.
    FixBot'a Sor
    Yorum Ekle
  8. Sony Alpha NEX-6 LCD Screen Replacement, Upper plastic separator: adım 8, 1 resimden 1.
    • Lift and slide out the upper black plastic separator using tweezers.
    FixBot'a Sor
    Yorum Ekle
  9. Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: adım 9, 3 resimden 1. Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: adım 9, 3 resimden 2. Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: adım 9, 3 resimden 3.
    • Lift and remove the lower black plastic separator using tweezers.
    • Using the pointy side of a spudger push in the screen lock button release it.
    • The screen lock button can now be removed.
    FixBot'a Sor
    Yorum Ekle
  10. Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: adım 10, 3 resimden 1. Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: adım 10, 3 resimden 2. Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: adım 10, 3 resimden 3.
    • Using the flat end of the spudger, push on the black nylon sheet glued to the metallic frame to peel it of.
    • Apply force from different spots to avoid tearing the sheet.
    • Remove the black nylon sheet using tweezers.
    FixBot'a Sor
    Yorum Ekle
  11. Sony Alpha NEX-6 LCD Screen Replacement, Screen Removal: adım 11, 1 resimden 1.
    • Gently wiggle the screen loose and remove it from the mount.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Clayton Dale
1.067 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G2
4 Üyeler
14 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thanks a million! Great guide and saved me $250 sending it back in.
Al Weiner - Yanıt Paylaş
Hi - I am trying to fix one of these -- and the guy I bought it from pulled off and lost the black locking latch from the ribbon cable rather than just lifting it -- I can get the LCD screen to light but can't keep it on very long -- I bought another one of these internal cables with the black locking latch. Do you think I can pop that one off and move it to this one? Or do you have any source of instructions how to replace that cable?
Cheers and thanks for this!
PS -- If anyone is just trying to get rid of the dreaded bubbles in the screen saver that plagues these NEX cameras -- it does just peal off -- see youtubes,,,
Harvey Cat - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 64
Her zaman: 8,210
