Ana içeriğe geç
Sony Alpha NEX-6 Lens-release Button Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-6 Lens-release Button Replacement, Finding the Release Button: adım 1, 1 resimden 1.
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: adım 2, 2 resimden 1. Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: adım 2, 2 resimden 2.
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens-release Button Replacement, Lens Mount: adım 3, 1 resimden 1.
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens-release Button Replacement: adım 4, 3 resimden 1. Sony Alpha NEX-6 Lens-release Button Replacement: adım 4, 3 resimden 2. Sony Alpha NEX-6 Lens-release Button Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens-release Button Replacement: adım 5, 2 resimden 1. Sony Alpha NEX-6 Lens-release Button Replacement: adım 5, 2 resimden 2.
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
  6. Sony Alpha NEX-6 Lens-release Button Replacement, Lens-release Button: adım 6, 1 resimden 1.
    • By using tweezers, carefully remove the lens-release button by lifting upward.
Sonuç
Clayton Dale
1.067 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,639
