Ana içeriğe geç
Sony Alpha NEX-C3 Back Panel Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-C3 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
  2. Sony Alpha NEX-C3 Back Panel Replacement: adım 2, 2 resimden 1. Sony Alpha NEX-C3 Back Panel Replacement: adım 2, 2 resimden 2.
    • Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
  3. Sony Alpha NEX-C3 Back Panel Replacement: adım 3, 1 resimden 1.
    • Tilt up the LCD screen.
    • Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
  4. Sony Alpha NEX-C3 Back Panel Replacement: adım 4, 1 resimden 1.
    • Gently pry off the back panel, by wiggling it around the LCD screen.
Sonuç
Jonathan Chen
690 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team S1-G1, Weedon Fall 2017 UC Santa Barbara, Team S1-G1, Weedon Fall 2017 üyesi
UCSB-WEEDON-F17S1G1
3 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 933
