Ana içeriğe geç
Sony Alpha NEX-C3 Control Wheel Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-C3 Control Wheel Replacement, Top Panel: adım 1, 1 resimden 1.
    • Turn the camera off by sliding the power switch.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Alpha NEX-C3 Control Wheel Replacement: adım 2, 1 resimden 1.
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Alpha NEX-C3 Control Wheel Replacement: adım 3, 1 resimden 1.
    • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Alpha NEX-C3 Control Wheel Replacement: adım 4, 2 resimden 1. Sony Alpha NEX-C3 Control Wheel Replacement: adım 4, 2 resimden 2.
    • Open the flap at the top of the camera.
    • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Alpha NEX-C3 Control Wheel Replacement: adım 5, 1 resimden 1.
    • Gently lift off the top panel with your hands.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Alpha NEX-C3 Control Wheel Replacement, Back Panel: adım 6, 1 resimden 1.
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Alpha NEX-C3 Control Wheel Replacement: adım 7, 2 resimden 1. Sony Alpha NEX-C3 Control Wheel Replacement: adım 7, 2 resimden 2.
    • Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  8. Sony Alpha NEX-C3 Control Wheel Replacement: adım 8, 1 resimden 1.
    • Tilt up the LCD screen.
    • Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  9. Sony Alpha NEX-C3 Control Wheel Replacement: adım 9, 1 resimden 1.
    • Gently pry off the back panel, by wiggling it around the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  10. Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: adım 10, 2 resimden 1. Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: adım 10, 2 resimden 2.
    • Grab the silver plate, and gently pry it up.
    FixBot'a Sor
    Yorum Ekle
  11. Sony Alpha NEX-C3 Control Wheel Replacement: adım 11, 2 resimden 1. Sony Alpha NEX-C3 Control Wheel Replacement: adım 11, 2 resimden 2.
    • Gently pinch blue ribbon cable, and pull it out of the port.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jonathan Chen
705 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team S1-G1, Weedon Fall 2017 UC Santa Barbara, Team S1-G1, Weedon Fall 2017 üyesi
UCSB-WEEDON-F17S1G1
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 75
Her zaman: 4,453
