Ana içeriğe geç
Sony Alpha NEX-C3 Top Panel Replacement
Neye ihtiyacın var
  1. Sony Alpha NEX-C3 Top Panel Replacement, Top Panel: adım 1, 1 resimden 1.
    • Turn the camera off by sliding the power switch.
  2. Sony Alpha NEX-C3 Top Panel Replacement: adım 2, 1 resimden 1.
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
  3. Sony Alpha NEX-C3 Top Panel Replacement: adım 3, 1 resimden 1.
    • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
  4. Sony Alpha NEX-C3 Top Panel Replacement: adım 4, 2 resimden 1. Sony Alpha NEX-C3 Top Panel Replacement: adım 4, 2 resimden 2.
    • Open the flap at the top of the camera.
    • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
  5. Sony Alpha NEX-C3 Top Panel Replacement: adım 5, 1 resimden 1.
    • Gently lift off the top panel with your hands.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jonathan Chen
705 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team S1-G1, Weedon Fall 2017 UC Santa Barbara, Team S1-G1, Weedon Fall 2017 üyesi
UCSB-WEEDON-F17S1G1
3 Üyeler
13 adet Kılavuz yazıldı
1Rehber Yorum
Sehr klar und verständlich, ich konnte ohne Probleme folgen.
Stephan Seidel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 995
