Ana içeriğe geç
Sony Alpha SLT-A55V Motherboard Replacement
Neye ihtiyacın var
  1. Sony Alpha SLT-A55V Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the focusing knob (indicated in red) located on the back of the camera to the right of the viewfinder.
    • Use a JIS bit size J0 or J00 from the iFixit screwdriver Kit.
  2. Sony Alpha SLT-A55V Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove all the screws on the bottom side of the camera.
    • Two screws, circled in orange, cannot directly be seen in this photo. One screw is hidden by the battery cap, and the other is hidden by the battery recess.
  3. Sony Alpha SLT-A55V Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the three screws in red from the right side of the camera.
  4. Sony Alpha SLT-A55V Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift the HDMI / USB cover on the left side of the camera, and remove the two screws in red.
  5. Sony Alpha SLT-A55V Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the black plastic sticker on top of the camera.
    • This sticker can be re-used. Peel the sticker off and place it on a clean piece of parchment paper or wax paper. This will prevent dirt and dust from getting on the adhesive.
    • Remove the two screws that lie beneath the sticker. The arrows indicate the location of these screws.
  6. Sony Alpha SLT-A55V Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove two screws from the left hand side of the camera.
  7. Sony Alpha SLT-A55V Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the two screws immediately below the flash. These screws are located on the face of the camera.
  8. Sony Alpha SLT-A55V Motherboard Replacement: adım 8, 1 resimden 1.
    • All the necessary screws are removed. Begin prying the back away from the camera in order to remove the front cover.
  9. Sony Alpha SLT-A55V Motherboard Replacement: adım 9, 1 resimden 1.
    • Pry open the enclosure carefully. The ribbon cables for the LCD are located on the right side and will need to be disconnected from the motherboard before removing the back of the case.
  10. Sony Alpha SLT-A55V Motherboard Replacement: adım 10, 1 resimden 1.
    • Some of the ribbon cables are held in with minature clips. These cables can be identified by the side hinge that can be released with a pointed end.
  11. Sony Alpha SLT-A55V Motherboard Replacement: adım 11, 1 resimden 1.
    • Once the back of the camera is removed the motherboard is exposed.
    • Remove all ribbon cables that are connected to the motherboard.
    • There are two ribbon cables that are stacked; the location is marked in orange. One cable is connected under the board, while the other is connected to the top
  12. Sony Alpha SLT-A55V Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove four screws to release the motherboard from the camera.
  13. Sony Alpha SLT-A55V Motherboard Replacement: adım 13, 1 resimden 1.
    • Carefully remove the motherboard using the precision tweezer set.
    • Use caution to prevent damage to the underlying electronics.
  14. Sony Alpha SLT-A55V Motherboard Replacement: adım 14, 1 resimden 1.
    • Once the motherboard has been completely unplugged and removed, it can be replaced and reassembled in reverse order.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sultan Almunif
357 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Wilson Fall 2015 IUPUI, Team 1-1, Wilson Fall 2015 üyesi
IUPUI-WILSON-F15S1G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Hi Mr Almunif
I have a SONY ALPHA SLT A55V that stopped working.
Sony South Africa quoted ZAR 17, 000 to repair this camera when the latest model over here will cost me ZAR 25, 000
Sony indicated that the camera needs a new Main PC Board and a Shutter Charge Unit or Shutter Change unit. Not sure from their handwriting on the quote
I can buy a new PC on ebay but need to find a charge unit
Can you assist with this and also on how to replace it
My previous A55 was stolen and the one I have is much needed to take videos of the properties that I sell for clients. m in the real estate business in South Africa
Regards
Chris Breet
CHRIS BREET - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 4,194
