Ana içeriğe geç
Sony Alpha a7S II Motherboard Replacement
Neye ihtiyacın var
  1. Sony Alpha a7S II Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the six 4mm screws located at the bottom of the camera using Philips #000 (Circled in red).
    • Remove the two 3mm screws remaining on the base plate using Philips #000 (Circled in orange).
    • Remove the base plate.
  2. Sony Alpha a7S II Motherboard Replacement: adım 2, 3 resimden 1. Sony Alpha a7S II Motherboard Replacement: adım 2, 3 resimden 2. Sony Alpha a7S II Motherboard Replacement: adım 2, 3 resimden 3.
    • Use the Philips #000 to remove the two 4mm screws located inside the battery holder.
    • Next, remove the two 4mm screws using the Philips #000 located on left side of the camera.
    • Remove one 4mm screw on the right side of the camera using Philips #000.
  3. Sony Alpha a7S II Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the two 3mm screws from the underneath the LCD screen.
    • Remove the screen.
  4. Sony Alpha a7S II Motherboard Replacement: adım 4, 2 resimden 1. Sony Alpha a7S II Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the rubber viewfinder cap by sliding it upwards.
    • Remove the four 3mm screws behind the cap.
  5. Sony Alpha a7S II Motherboard Replacement: adım 5, 2 resimden 1. Sony Alpha a7S II Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the outer case.
    • Unhook the component outlined by the red square.
    • Next, unscrew the two 4mm screws circled in orange using the Philips #000.
    • Remove the button outlined with the yellow square.
  6. Sony Alpha a7S II Motherboard Replacement: adım 6, 2 resimden 1. Sony Alpha a7S II Motherboard Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the 4 mm screw from the housing.
    • The access door on the side of the camera must be open to reach the screw and remove the copper plate.
  7. Sony Alpha a7S II Motherboard Replacement: adım 7, 3 resimden 1. Sony Alpha a7S II Motherboard Replacement: adım 7, 3 resimden 2. Sony Alpha a7S II Motherboard Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently pull the clip up on the wire ribbon ports.
    • Using the tweezers, gently pull the wire ribbons out of the ports.
    • Once the ribbon cables are disconnected, the motherboard can be removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
IUPUI, Team 1-5, Beck Spring 2022 IUPUI, Team 1-5, Beck Spring 2022 üyesi
IUPUI-BECK-S22S1G5
4 Üyeler
1 Kılavuz yazıldı
2 Yorum
Where can I order the motherboard for this camera?
Joshua Davis - Yanıt
You can find replacement parts on Aliexpress.
Lou Bariller -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 94
Her zaman: 3,243
