Ana içeriğe geç
Sony Alpha a7s II Tripod Mount Replacement
Neye ihtiyacın var
  1. Sony Alpha a7s II Tripod Mount Replacement, Tripod Mount: adım 1, 2 resimden 1. Sony Alpha a7s II Tripod Mount Replacement, Tripod Mount: adım 1, 2 resimden 2.
    • Orient your camera so that you are looking at the bottom portion.
    • Using a JIS #00 screwdriver, remove the 7 screws that are securing the metal plate to the bottom of your camera.
    • You do not need to remove that recessed screw that is not connected to the bottom metal plate.
  2. Sony Alpha a7s II Tripod Mount Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove metal plate. Sometimes this plate can become stuck and hard to remove. Use tweezers to separate the plate from the bottom of the camera.
  3. Sony Alpha a7s II Tripod Mount Replacement: adım 3, 1 resimden 1.
    • Flip the plate to the opposite side exposing the aspect that was just inside of the camera.
    • Use the JIS #00 screwdriver to unscrew the the 3 screws surrounding the tripod mount.
  4. Sony Alpha a7s II Tripod Mount Replacement: adım 4, 1 resimden 1.
    • Remove the tripod mount from the metal plate.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 2,886
