Ana içeriğe geç
Sony BDP BX350 Device Control Board Replacement
Neye ihtiyacın var
  1. Sony BDP BX350  Device Control Board Replacement, Control Board: adım 1, 1 resimden 1.
    • Remove the three 10mm Philips head screws on the back of the player.
    FixBot'a Sor
    Yorum Ekle
  2. Sony BDP BX350  Device Control Board Replacement: adım 2, 1 resimden 1.
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
    FixBot'a Sor
    Yorum Ekle
  3. Sony BDP BX350  Device Control Board Replacement: adım 3, 1 resimden 1.
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
    FixBot'a Sor
    Yorum Ekle
  4. Sony BDP BX350  Device Control Board Replacement: adım 4, 1 resimden 1.
    • Remove both covers.
    FixBot'a Sor
    Yorum Ekle
  5. Sony BDP BX350  Device Control Board Replacement: adım 5, 2 resimden 1. Sony BDP BX350  Device Control Board Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Sony BDP BX350  Device Control Board Replacement: adım 6, 1 resimden 1.
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
    FixBot'a Sor
    Yorum Ekle
  7. Sony BDP BX350  Device Control Board Replacement: adım 7, 2 resimden 1. Sony BDP BX350  Device Control Board Replacement: adım 7, 2 resimden 2.
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Cameron Peterson
113 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G5, Catania Spring 2017 UMass Dartmouth, Team S8-G5, Catania Spring 2017 üyesi
UMASSD-CATANIA-S17S8G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 735
