Ana içeriğe geç
Sony BDP BX350 Disc Assembly Replacement
Neye ihtiyacın var
  1. Sony BDP BX350 Disc Assembly Replacement, Disc Assembly: adım 1, 1 resimden 1.
    • Remove the three 10mm Philips head screws on the back of the player.
    FixBot'a Sor
    Yorum Ekle
  2. Sony BDP BX350 Disc Assembly Replacement: adım 2, 1 resimden 1.
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
    FixBot'a Sor
    Yorum Ekle
  3. Sony BDP BX350 Disc Assembly Replacement: adım 3, 1 resimden 1.
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
    FixBot'a Sor
    Yorum Ekle
  4. Sony BDP BX350 Disc Assembly Replacement: adım 4, 1 resimden 1.
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
    FixBot'a Sor
    Yorum Ekle
  5. Sony BDP BX350 Disc Assembly Replacement: adım 5, 1 resimden 1.
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
    FixBot'a Sor
    Yorum Ekle
  6. Sony BDP BX350 Disc Assembly Replacement: adım 6, 1 resimden 1.
    • Pull the disc assembly out from under the metal tabs on the main casing.
    FixBot'a Sor
    Yorum Ekle
  7. Sony BDP BX350 Disc Assembly Replacement: adım 7, 1 resimden 1.
    • Remove disc assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kristen Vezina
413 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G5, Catania Spring 2017 UMass Dartmouth, Team S8-G5, Catania Spring 2017 üyesi
UMASSD-CATANIA-S17S8G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 640
