Ana içeriğe geç
Sony BDP BX350 Motherboard Replacement
Neye ihtiyacın var
  1. Sony BDP BX350 Motherboard Replacement, Disc Assembly: adım 1, 1 resimden 1.
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Motherboard Replacement: adım 2, 1 resimden 1.
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Motherboard Replacement: adım 4, 1 resimden 1.
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Motherboard Replacement: adım 5, 1 resimden 1.
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Motherboard Replacement: adım 6, 1 resimden 1.
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove disc assembly.
  8. Sony BDP BX350 Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Sony BDP BX350 Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Do not bend or tear the ribbon cable.
    • Remove all five ribbon cables from the motherboard.
  9. Sony BDP BX350 Motherboard Replacement: adım 9, 1 resimden 1.
    • Unscrew 3mm Philips head HDMI screw from metal casing.
  10. Sony BDP BX350 Motherboard Replacement: adım 10, 1 resimden 1.
    • Unscrew the three 5mm Philips head screws from motherboard.
    • Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
Sonuç
Kristen Vezina
413 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G5, Catania Spring 2017 UMass Dartmouth, Team S8-G5, Catania Spring 2017 üyesi
UMASSD-CATANIA-S17S8G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 661
