Ana içeriğe geç
Sony BDP BX350 Wifi Card Replacement
Neye ihtiyacın var
  1. Sony BDP BX350 Wifi Card Replacement, Control Board: adım 1, 1 resimden 1.
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Wifi Card Replacement: adım 2, 1 resimden 1.
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Wifi Card Replacement: adım 3, 1 resimden 1.
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
  4. Sony BDP BX350 Wifi Card Replacement: adım 4, 1 resimden 1.
    • Remove both covers.
  5. Sony BDP BX350 Wifi Card Replacement: adım 5, 2 resimden 1. Sony BDP BX350 Wifi Card Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
  6. Sony BDP BX350 Wifi Card Replacement: adım 6, 1 resimden 1.
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
  7. Sony BDP BX350 Wifi Card Replacement: adım 7, 2 resimden 1. Sony BDP BX350 Wifi Card Replacement: adım 7, 2 resimden 2.
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
  8. Sony BDP BX350 Wifi Card Replacement, Wifi Card: adım 8, 2 resimden 1. Sony BDP BX350 Wifi Card Replacement, Wifi Card: adım 8, 2 resimden 2.
    • Remove 6mm Philips head screw from wifi board.
  9. Sony BDP BX350 Wifi Card Replacement: adım 9, 1 resimden 1.
    • Remove the ribbon cable from motherboard using a pair of tweezers.
  10. Sony BDP BX350 Wifi Card Replacement: adım 10, 3 resimden 1. Sony BDP BX350 Wifi Card Replacement: adım 10, 3 resimden 2. Sony BDP BX350 Wifi Card Replacement: adım 10, 3 resimden 3.
    • Carefully remove board and ribbon cables by pulling upwards then out to free it from the metal clips.
Sonuç
Kristen Vezina
413 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G5, Catania Spring 2017 UMass Dartmouth, Team S8-G5, Catania Spring 2017 üyesi
UMASSD-CATANIA-S17S8G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 309
